Motorcycle Restoration Stand for 34 VL
  • leomags
    • Dec 2008
    • 46
    I have a 1934 VL which I plan to restore. What type of stand can I build which will hold the frame for disassembly and assembly?
    • 5954
    Use the rear stand on back and and axle stands on the footboard support rod on the front.
    • sirhrmechanic
      Vigilis
      • Dec 2010
      • 1147
      I have a hydraulic lift that I bought from JP cycles. About $250, as I recall. Lifts bike up to a comfortable height. You can strap/clamp the frame in place and it's quite secure. Locks in place at the top. I've seen better and more expensive units and some really slick hydraulic/pneumatic tables. But this gets the job done for a reasonable cost.
      This is at full height with my EL
      This is a better picture of the stand with my '64 FLF under restoration.
        • 5954
        You have to remember that a VL has a single tube frame. Not double tubes like your EL and FL.
        • Re-cycleInc
          • May 2009
          • 43
          Here's what I use for my 45's....a combination of Chris' idea and the jack that sirhrmechanic is using. The rails go under the floorboard support rods. I made it and then realized that the cam chest hit the rail so that's why I have the cutout. It worked fine, but I plan to reinforce the cut-out
          Scott
          AMCA# 13993
          • sirhrmechanic
            Vigilis
            • Dec 2010
            • 1147
            To Chris:
            Good point. I am going to go and adjust my 'dummy' sign now! I have it on crooked.
            To Scott: Nicely done!
            Cheers, Sirhr
