Schebler DLX ID
  • Mr. Big
    • Feb 2010
    • 130
    Schebler DLX ID
    Got this little carby and unfortunately someone has tinkered with the last digit.
    Schebler DLX5..something. Only thing I've been able to find close to that is a DLX53 in a 1-1/4" carb. The stem casting has DL 57 on it and the bowl had DL 4 stamped on it. Only other carbs I found that start with a 5 are 1" carbs. Any thoughts?
    47 WL
    51 Ls Sidecar
    03 FLHT
    http://www.gouldingsidecars.com
  • bselph
    • Jun 2009
    • 311
    I have a DLX55 that has a 7/8 venturi on my 1933 VC. I can't find it listed anywhere either. I do need a choke lever for it. It is just like yours.
    Bob Selph
    1933VC/1934LT Sidecar
    1940 Sport Scout
    AMCA#15215
      • 8247
      Mr. Big!
      There are many unlisted numbers for Scheblers. When we cannot declare them a commercial motor or import model, we just call them "mystery" Scheblers.
      Note however, that yours has Linkert needles and LS lift lever.
      ......Cotten
      • Mr. Big
        • Feb 2010
        • 130
        Thanks Cotten. I was thinking that might be the case. Close examination by a few people thought that it started out as a 9 then hit with an 8 and a 3. In any case it's a mess. bselph, if you need the lever I'd accept a small amount for it. That's if I can get the dang thing off.
        47 WL
        51 Ls Sidecar
        03 FLHT
        • bselph
          • Jun 2009
          • 311
          I would love to have the lever. Please contact me if you can get it off bselph116@comcast.net
          Thanks, Bob
          Bob Selph
          1940 Sport Scout
          AMCA#15215
