One of the European dealers was advertising petcocks that they guaranteed not to leak.
Leaky Fuel petcocks
I’ll take a look for those. Today I spent a lot of time attempting to repair the ones I have. I lapped them lightly by hand with grease mixed valve grinding compound and then used toothpaste. These were the only materials I had available. Afterwards I added washers for a much tighter fit. Have not tested them with fuel yet. I have 4 petcocks in total 2 originals and 2 from VTwin. All I really need is one reliable one to use on the main right side tank.Justin Monti
AMCA #43973
Originally posted by dukekleman View PostAs Merdog1968 mentioned, I also use Viton Flouro. Brown O-rings in petcock valves to stop fuel leakage. I've Been using them well over 25 years now and they work great. However ,They do need replacement overtime like any O-ring, Gasketing material or seal.
DukeJustin Monti
AMCA #43973
Originally posted by tomfiii View PostO rings stop valve from dripping ,but gas will still not completely shut off. A little EZ-Turn on valve before assembly helps.
Thank you for mentioning it I’m going to buy some.Last edited by montij; 01-03-2024, 11:14 PM.Justin Monti
AMCA #43973
