45 Flathead Belly Numbers
  • bmh
    replied
    I've seen at least one 49 motor where the belly numbers were higher than the serial. These things weren't kept in any order on the shelves any more than anything else. I highly doubt that any part of the VIN was placed on the case until the motor was ready to be married to a frame at the production line. If the VIN was present what was the purpose of the "7"'s stamped at the rear mount on FL motors? You'd be able to tell if it was a 74" or a 61" motor by the VIN.
  • knuckleheadtim
    replied
    I don't think it's likely the belly numbers were attained by adding or subtracting the employee number from the VIN for several reasons:
    1) It would allow for duplicate belly numbers; IE
    4487 + 150 = 4637
    4517 + 120 = 4637
    2) Many early engines I've seen have a belly number lower than the VIN. I have a very early '38 motor with a high '37 belly number. As the year progressed, the belly numbers are closer to the VIN because replacement cases were sold without VIN numbers stamped. By the end of the year, the belly number is much higher (over 1000 in '47). At some point, they would have crossed, but not necessarily matched, since the motors weren't likely taken off the rack in numerical order to build bikes.
    3) Three different stamp sets were used on each motor; the year on the belly, the 4 or 5 digit belly number, and the VIN number. This suggests the belly number was put on the matching cases and the VIN added after the bike was completed. The belly numbers were indeed stamped to identify a machined set. but they wouldn't assign a VIN to replacement cases.
  • flat-happy
    replied
    Originally posted by bselph View Post
    Thanks guys. Matching belly #'s 33-3460 and serial # 33VC33_ _. Looks like I have a correct engine and the numbers fall within flat-happy's 125 employee theory.
    please don't take my theory as fact though as i have no way of proving it. i was just going by what a guy told me who used to build engines for the factory. i doubt there is anyone working at the moco now who could back up that information but i haven't seen anyone tell me any other theory of the correlation between the vin and machining numbers either. we may never know now
  • bselph
    replied
  • Chuck#1848
    replied
    I will check for other numbers tonight. My vin appears to be original stamping.
    Thanks for the help.
    You will most likely need a drop light and a mirror to see the numbers but the should start with the year of the bike followed by the mating numbers
  • bselph
    replied
  • Perry Ruiter
    replied
    Since we are talking about belly #'s, my 33VC has the following: 112-30F right side and 112-30H left side. What does the F & H mean?
    Those aren't your motor's belly numbers. Those are the mold casting numbers ... Perry
  • bmh
    replied
    Sorry Rub, I had the wrong parts book open on my desk the other night, you are correct, my mistake. I didn't look at the part numbers , only saw that no single cases were listed.
  • Rubone
    replied
    bselph,
    Why does your '33 have '30 cases? Are your numbers original?
    Robbie
  • Rubone
    replied
    Brian,
    Yes, they were. And I am not sure where you are getting your information as my original '54 parts book lists the crankcases individually available by side!
    Robbie
  • bselph
    replied
  • bmh
    replied
    Rub, still think somethings a little fishy, crankcases were only available as sets according to the 54 parts book. Were they available separately in years prior?
  • Paps
    replied
    Originally posted by Ohio-Rider View Post
    Maybe a rush job came thru and machinist needed to tear down his setup. I always hated when that happened, and it happened way to often.
    Know those rush job issues way to well also Steve. But the MoCo ? It is unlikely someone was down and was willing to stop a production line there...heh ? Job shops are bit different. Especially when you got downed steel mills, BOC, GMC, Delphi, etc., etc.. Oh yeah...I remember many of those times well. 'THE BOSSES" Ok boys !!!! Tear those machines down now !!! We are on 24's until we get this new downtime job completed ! Ah yes !! The company raked in the doe then ! And us ? We got overtime. LOL
  • Ohio-Rider
    replied
  • Paps
    replied
    Are they not cam bore numbers as well Chris, since the main bore would be the zero point for all other case bores ? I mean.....what is the sense of putting a line bore in, and not the rest of the holes, when the cases are already setup for such machining ?
