45 Flathead Belly Numbers
  • Ohio-Rider
    Supporting Member
    • 852
    I’ve been researching information about belly numbers on the flatheads and haven’t found much useful information, so I figured I ask you guys. Here are my top three questions I’ve been trying to find info on.
    Do the belly numbers on a flathead tell us more than just the year they where assembled together?
    What can the five digit number following the year the cases where stamped tell me?
    Is there any relationship between the belly numbers and the VIN number stamp on the left pad?
    Thanks in advance. -Steve
    Steve
    AMCA #7300
  • bmh
    • Feb 2007
    • 901
    The numbers you refer to only tell us the year in which the case halves were mated and machined as a set and what their place in the machining order was. They were marked to insure they remained a set during production and also to help the police in the event of theft to verify the VIN. The Factory kept records of which motor # was built with which set of cases, but those files are long since gone. there is no real relationship between the serial number and the case numbers, it was a matter of which parts got grabbed from stock at what time to build a machine. The only real thing I can think of is that if your belly numbers are older than the casting date codes inside, something is amiss.
    Brian Howard AMCA#5866
    • Paps
      • Jun 2003
      • 1814
      Something is a miss if your vin number is older than your belly numbers also. Low vin numbers would indicate low belly numbers, provided the vin numbers are original. Especially on type III and earlier wla's. IMHO Paps
        On the VLs the belly numbers are within a few hundred of the VIN numbers, showing the level of engine cases held in intermediate stocks. The exception is 1930, where the first 2000 cases were recalled and replaced (we think) with new cases with the same engine numbers. The case numbers therefore run a couple of thousand ahead of the engine numbers (plus or minus a couple of hundred as above) for this season only.
        For the 42WLAs, these were built until 1944, so you can find them with 1942, 1943 and 1944 belly numbers but still with 42WLA engine numbers going up over 70,000. Not all will have five digit belly numbers, as the first 9000 each year presumably have belly numbers in the 1000-9999 range.
        It would be nice to think the factory records survive linking the engine and belly numbers, so we can retrieve the original engine number from a good belly number. I've never had any luck finding these. It's possible the military bikes are better documented, with records in Army possession even if cleared out of the Harley archive. Keep asking.
        • Ohio-Rider
          Supporting Member
          • 852
          Now I’m a little more confused than normal. How could an engine have a five digit belly number with a four digit VIN number? -Steve
          Steve
          AMCA #7300
          • cdndewey
            • Jan 2005
            • 438
            I don't see where you read that...can you point me in that direction.
            • Ohio-Rider
              Supporting Member
              • 852
              Sorry for the confusion. Its not something I read, rather it is something I own. I have a 1945WL with matching five digit belly numbers and a four digit VIN number.
              Steve
              AMCA #7300
              • BEK
                • Dec 2003
                • 75
                belly numbers
                Steve (Ohio-Rider),
                I believe that in 1945 they made a lot of 45 motors that never got VIN's, that were used as replacement motors. I used to own such a motor that had 5 digit belly numbers, from '45, and no VIN.
                Bruce Keith
                AMCA #1467
                • Paps
                  • Jun 2003
                  • 1814
                  Steve, This particular case half is from one of my 42wla case sets. All my case sets have matching belly numbers. The vin for this particular engine is a low un altered 5 digit 42 early type III wla. Earlier 42 wla's only had a 4 place vin after the year designation. Note the 5 place belly number. It is still a 42 machining job though. IMHO....since your vin is a 45 and your belly numbers are 45*****, then you have a pretty perfect match. I don't believ your cases to be replacement cases. Paps
                  • Ohio-Rider
                    Supporting Member
                    • 852
                    Great picture Paps, That looks just about where I found mine.
                    Ok…. I get it. It’s an apple and orange’s thing.
                    To bad that list, matching belly numbers to VIN numbers has been lost. -Steve
                    Steve
                    AMCA #7300
                    • Paps
                      • Jun 2003
                      • 1814
                      Their are folks still pursuing that list Bro. I really believe the list will become public one day. If not via the MoCo...via the military.
                        • 5955
                        It is not lost. It is in the H-D Service department. It is only available the H-D dealers and law enforcement. It is a numerical list of line bore numbers with the serial number applied to that case next to it.
                        • cdndewey
                          • Jan 2005
                          • 438
                          That's interesting Steve. I just went and checked my 42 and 43 WLC's and the 43 also has a 5 digit belly number and a 4 digit VIN, and the 42 has 5 digits on both numbers.
                          • Paps
                            • Jun 2003
                            • 1814
                            I can unstand that Chris but those records should be available to the public now, just like automotive vin numbers are now. Carfax for example. I would think the MoCo has not got all of the military vin data though. I doubt very much the military contacted the MoCo, everytime they changed out an engine, especially on the field of battle. The military noted the mil spec registration from one engine to another, the original mil spec registration denoted to the original factory produced machine would have been reassigned to the replacement engine. I sincerely doubt the MoCo received that information. It is that data...the military data...which is really lost and yet found. Paps
                              • 5955
                              So Paps,
                              Consider if an unscrupulous person knows both line bore numbers and the serial number that went with it. And he also has a set of stamps. Number jobs would rise to new heights.
