Chasing the idle speed on my WLA
  • RvP
    • Aug 2005
    • 105
    Maybe I am asking too much of my 45 but I have been chasing the idle on it for the last 3 years with different iterations of motor changes to get it back to stock. When the engine is cold I have a nice “putt – putt” idle (spark fully advanced), so slow the generator light flickers. When the engine warms up during a high speed run the idle speed is high at the next stop, almost racing. I have to retard the spark and it gets slower but not at a speed I would call an idle, more like a fast idle. If I turn the hot engine off and start it 15 minutes later the idle is back to the “putt-putt” mentioned above.
    Regardless of the iterations in getting this engine right it now has the following:
    New barrels, pistons, rings, valves, valve springs, head and base gaskets.
    Aluminum #5 heads with Teflon gaskets.
    The intake manifold has the extension between the carb and the manifold, some call this a heat blocker but I have read it does not block heat but moves the carb out from between the hot cylinders. All the mating surfaces look flat and mate without any noticeable warps.
    The carb is an M88 with adjustable high speed. The location for the high speed jet is plugged with a brass plug and so is the other hole.
    New throttle shaft with barely discernable “wiggle” in the throttle shaft bushings. Just to be on the safe side I squashed an “O ring” under the throttle arm to seal better as a last resort.
    I have cleaned the carb including making sure the two little holes where the butterfly closes are open.
    The vent in the venturi is clear.
    The nozzle is not stuck but it does not readily fall out when the bowl and spring are removed. A few thumps on the carb body by hand and gravity is all it takes to get it out.
    The venture is tight and I have not removed it.
    This sounds like an air leak to me but I can not figure out where it is.
  • RvP
    • Aug 2005
    • 105
    Forgot to mention....
    New float and adjusted per the military engine rebuilding manual
    New brass compression fittings on the intake manifold to cylinder fittings
    If no one has a solution, is there a diagnsotic technique I can use to find the problem area.
    • knuckleheadtim
      • Jan 2008
      • 141
      Do you have the correct tophat washer installed under the idle mixture needle spring? It should be about .103" ID.
        • 8243
        Rvp!
        Although your carb may have common issues (like daylight around the venturi, or excessive borewear), it is far more likely that your tuning difficulties originate downstream. Even though your brass ferrules are new, it is most important to pressuretest the assembly with soapy water upon it to be certain that you do not chase your tail. Just 12 to 15 psi max is all it takes for even the tiniest gremlin to show itself as a blister of foam.
        Just get a big rubber stopper that fits your manifold and poke a hole in it for your air supply. (And wash any detergent off afterwards because it is corrosive!)
        Good luck,
        • RvP
          • Aug 2005
          • 105
          Chasing the idle
          Thanks to those that responded. There is a "top hat" washer on the idle mixture needle, whether it is correct or not I will have to measure it.
          Never though to pressure test the intake manifold to cylinder connections. Assuming I do find a leak (lots of foaming) how to I correct this? Can I just mash silicon into the joints and wipe it clean?
          • Paps
            • Jun 2003
            • 1814
            Nope....use peek seals. Paps
            • RvP
              • Aug 2005
              • 105
              Do not know what peek seals are...
              OK, you got me on that one. What are peek seals?
              • George Greer
                • Jul 2007
                • 151
                Pa..........
                I got PEEK seals, on the WLA
                AND just got in my DuraFloats from Cotten...
                Just about spent a couple hours making sure the float's set up right..
                Will exchange the bowl this weekend....and runer up.
                Now...........since I was using the heavy brass float and now gone to one that's only about 3 grams....
                What am I looking for, as far as carb needle adjustments?
                RvP........Tom Cotton makes PEEK seals.......contact him.
                George
                George Greer
                AMCA # 3370
                • DrJ
                  • May 2008
                  • 2
                  press.-test is a good way to go. That said, you can also bring engine up to approx. 2,000rpm and carefully spray something like WD-40 around each area you want to test. Any signif. change in eng. speed (up or down) indicates a likely leak.
                  Let me know how this turns out as I have the exact same symptoms on my '71 shovel, can't find a leak and am not sure what's going on.
                    • 8243
                    Spraying stuff like WD-40 or even using a fire extinguisher will only give a result if the vacuum leak is quite large. And you still can only guess the whereabouts.
                    The tiniest fissures that only make a tiny blister of foam under pressure are enough to make cylinders burn differently, and affect tuning. Bubbles pinpoint problems when they exist.
                    A brief discussion at http://virtualindian.org/11techleaktest.html addresses places other than the ferrules where leaks may occur.
                    Pressuretesting WHILE installing later O-ring assemblies allows you to find the 'sweet spot' of a perfect seal before you go to the trouble of installing the carb, as well as preventing over-tightening of the clamps.
                    More and more shops around the world are machining worn manifolds and the thermoplastic PEEK to fit 'plumber's' manifolds.
                    http://www.enfieldracing.com/8.html now offers cast ferrules, however your manifold spigots will have to be in pristine condition to accept them properly.
                    • motorhead1
                      • Dec 2006
                      • 171
                      Originally posted by bueutyygo
                      bump the thread up. In 1945, a 12-year-old boy saw something in a shop window that set his heart racing. But the price—five dollars—was far beyond Reuben Earle's means. Five dollars would buy almost a week's groceries for his family.  Reuben couldn't ask his father for the money. Everything Mark Earle made through fishing in Bay Roberts, Newfoundland, Canada. Reuben's mother, Dora, stretched like elastic to feed and clothe their five children.  Nevertheless, he opened the shop's weathered door and went inside. Standing proud and straight in his flour-sack shirt and washed-out trousers, he told the shopkeeper what he wanted, adding, “But I don't have the money right now. Can you please hold it for me for some time?”  “I'll try," the shopkeeper smiled. “Folks around here don't usually have that kind of money to spend on things. It should keep for a while.”Thsale is a professional, loyal and reliable wow gold supplier online, we pioneered selling cheap wow gold. Welcome to thsale buy world of warcraft gold Buy Cheap WoW Gold, World of Warcraft Gold, Please look here! We are a Great MMORPG company. wow money and wow items,which is very cheap WOW Gold!All US Server 24.99$/1000G on sell! Cheap wow gold,rs powerleveling,wow power leveling,Buy Cheapest/Safe/Fast WoW US EU Gold Power leveling --------------------------------our wow gold site:buy WoW Gold,cheap WoW Gold,free WoW Gold, buy wow power leveling,cheap wow power leveling,
                      WTF is this? Is this what I get for $30 a year?
                      Ride 'em. Don't hide 'em.
                      Dan #6938 FUBO
                        • 5955
                        As far as the leadership of this club is concerned it is.
                        • George Greer
                          • Jul 2007
                          • 151
                          Aaahhhhhhhh
                          Makes me wonder about renewing.....
                          Although at each B/B that I am at/member of I learn something...but this spam crap is BS...
                          George Greer
                          AMCA # 3370
