VL fuel mileage - what to expect?
  • VL fuel mileage - what to expect?
    OK, the VLD is alive and today's test ride went much better than the last one which ended up with a not so zippy spark coil and a flatbed ride home.
    The question of the day is.......while mileage will vary (that's bad, I know).....what should a VL get for miles to the gallon? Or, how many miles will a full primary tank provide?
    Thanks!
    I'll answer my own question.
    The VLD is getting roughly 45mpg. The primary tank holds a little more than 2.5 gallons of gas but I've never run it dry.
      I've always got decent milage out of my VL, I would say closer to 40 MPG. A better question may be how many miles per quart of oil.
        On a 700-mile trip with '35 VDS,average speed 45mph, low gearing, heavily loaded sidecar 30 mpg. Accompaning buddies on '27 JD and '31 DL got 45 mpg respectively 50 mpg.
        Fiskis
          MPG
          my left side tank has a lot of rust so i don't use it, with the right i always figure on 100 miles tops.i.e. 40 mpg
