1934 VD issues
    • 8243
    Originally posted by 34VDharley View Post
    Sorry for my ignorance but whats a bubble test?
    A constant, regulated air supply, 34VD,
    No more than fifteen psi, and soapy water:
    .....Cotten
    • JoJo357
      • Feb 2016
      • 3299
      *M.A.D.*
      • 34VDharley
        • Jun 2025
        • 48
        So, motor kicks freely now. No more binding etc. I got her to start briefly and she sounded OK, but definitely something is still off. I plan to mess with it over the holiday weekend.
        • 34VDharley
          • Jun 2025
          • 48
          FYI the plugs were fine. Slightly dirty but nothing showing major issues.
          • JoJo357
            • Feb 2016
            • 3299
            Please keep us informed Tim. Curious as to what is the culprit. Thank You.
            *M.A.D.*
            • 34VDharley
              • Jun 2025
              • 48
              So replaced the plugs with new D16 plugs. Drained the oil and it was black and definitely silvery. Primed her and she kicked over first kick but only runs smoothly at mid throttle. I was able to ride her around my storage area but she wasnt quite right...bit did operate okay. When I parked her I had this draining out the oil chain brush. Thoughts?
                • 2024
                I think you have a badly scored front cylinder. Jerry
                  • 8243
                  Probably, Jerry!
                  But that probably wasn't where the fuse was lit.
                  • JoJo357
                    • Feb 2016
                    • 3299
                    Tim, you'll only make matters worse than they already are by riding for a diagnosis cure. Park it, and have a competent mechanic check it over.
                    *M.A.D.*
                    • 34VDharley
                      • Jun 2025
                      • 48
                      Curious to get why people believe that might be the case? It almost sounds as if the values aren't adjusted right on the front. In any event I'll have Jason Simms take a look at it when he can. Again it'll start every first kick even when hot.
                        • 8243
                        ....Bike was smoking like a chimney....
                        ....Curious to get why people believe that might be the case? It almost sounds as if the values aren't adjusted right on the front. In any event I'll have Jason Simms take a look at it when he can. Again it'll start every first kick even when hot.
                        Because you got it very *HOT*, Tim.
                        Heat does the damage, as a chain reaction taking out the hottest part first, which is usually the front cylinder.
                        But the front cylinder was the victim, not the culprit.
                        Hope Jason can take suggestions better than you have.
                        • 34VDharley
                          • Jun 2025
                          • 48
                          #27
                          T. Cotten alright no need to be rude. Simply asking questions and seeking answers. Jason Simms is a well known flathead guy and was the one who helped sell the bike to me.
                            • 8243
                            #28
                            You requested advice, Tim.
                            I provided a time-tested diagnostic.
                            Sorry if you are triggered, but you ignored it.
                            You can lead a horse to water, but everybody else better drink before it pisses.
                            • 34VDharley
                              • Jun 2025
                              • 48
                              #29
                              Na you didn't trigger me at all but your brash responses make ya come across as the backside of a barn animal.
                              In any case I have a few more tests to run which also include pulling the heads to inspect the cylinders.
                                • 8243
                                #30
                                Na you didn't trigger me at all but your brash responses make ya come across as the backside of a barn animal....
                                You're right, Tim.
                                I don't get out of the barn enough.
