Rocker clutch spring stud install
  • montuckymatt
    • Jan 2019
    • 44
    I’m about to peen the NOS clutch spring stud on my rocker clutch. The spring mount part of the stud finally broke off from use. Any tips on setup for doing this? I figure there has to be a better way than just throwing it in the vice and swinging away.
    Nothing left to do but smile, smile, smile....
    -good ol GD
  • Chris Haynes
    Curmudgeon
    • Jul 2002
    • 5950
    Heat the end to be peened red hot. Use a correct rivet set to make it look original.
    • marksg
      • Mar 2023
      • 128
      Does someone make a replacement spring stud? Sounds easier than welding and reshaping.
      • montuckymatt
        • Jan 2019
        • 44
        Colony does. I found a OEM one in the package on eBay for about $20. The guy I bought mine from has one more….here is a link
        https://www.ebay.com/itm/23676136975...Bk9SR_6w8KS7Zw
        -good ol GD
        • marksg
          • Mar 2023
          • 128
          Thank Matt.
            Gadfly from the Dumpster
            • 8233
            Did the MOCO, Chris,..
            Do them red hot?
            Thanks,
            • Jerry Wieland
              • Jan 2006
              • 2018
              Do them red hot?
              Thanks,
              I think the factory did them cold in a trip hammer.
              Jerry
              • BigLakeBob
                • Jul 2010
                • 2767
                I think this would be the best method for the home repairman, I doubt most have access to a trip hammer or a 30 ton press to do it cold, my opinion.
                Bob Rice #6738
                  • 8233
                  Trip hammers are rare indeed, BLB,
                  But most of us at least have a press.
                  PS: Thirty tons would flatten it!
                  • montuckymatt
                    • Jan 2019
                    • 44
                    I’m pretty limited in my shed but I got it red hot and peened it. Worked like a charm. Time to pull off the repop rocker clutch and put a real one on!
                    -good ol GD
