I’m about to peen the NOS clutch spring stud on my rocker clutch. The spring mount part of the stud finally broke off from use. Any tips on setup for doing this? I figure there has to be a better way than just throwing it in the vice and swinging away.
Rocker clutch spring stud install
Tags: None
Heat the end to be peened red hot. Use a correct rivet set to make it look original.Be sure to visit;
Colony does. I found a OEM one in the package on eBay for about $20. The guy I bought mine from has one more….here is a link
https://www.ebay.com/itm/23676136975...Bk9SR_6w8KS7ZwNothing left to do but smile, smile, smile....
-good ol GD
I think this would be the best method for the home repairman, I doubt most have access to a trip hammer or a 30 ton press to do it cold, my opinion.Originally posted by Chris Haynes View PostHeat the end to be peened red hot. Use a correct rivet set to make it look original.Bob Rice #6738
Trip hammers are rare indeed, BLB,Originally posted by BigLakeBob View Post
But most of us at least have a press.
PS: Thirty tons would flatten it!Last edited by T. Cotten; 04-30-2026, 11:02 AM.AMCA #776
I’m pretty limited in my shed but I got it red hot and peened it. Worked like a charm. Time to pull off the repop rocker clutch and put a real one on!Nothing left to do but smile, smile, smile....
-good ol GD
