41 u tranny
  • cheifrider
    41 u tranny
    trying to replace the kicker bushings in a 41 u tranny..........when i took the throwout bearing out and shook it ,it sounded like my skull full of marbles."plenty of room in there"IS THIS NORMAL ON THIS THIS TRANNY , I THINK NOT BUT THOUGHT I WOULD CHECK. THANKS AGAIN ,TOM sorry about the caps
  • Rub
    The throwout bearings pretty much always sound like that if shaken. They are thrust bearings and work when there is a side load on them. Hold the outside of the bearing and push the inner half against it and rotate it. It should feel smooth when checked that way. Robbie
    • cheifrider
      thanks robbie , i think ya just saved me $50
      • 41Craig
        Throw Out Bearing
        Another easy way to check these old throw out bearings is to place it on a clean spot on the floor(small side up) and place your foot on it. Twist your foot back and forth with part of your weight on it ( this acts the same as the clutch spring pressure). It should feel nice and smooth. Any roughness indicates that it's shot.
