G motor cases
  • jruff
    • May 2023
    • 96
    G motor cases
    The first thing I do before posting a questing is doing search, so I don't waist peoples time, it never works. I've tried 'g motor' "g motor" plain g motorcycle anything with more then one word splits up the search. The question is are there any difference between a WL and a G set of cases, will everything from a WL swap over to a G motor? Also is there a way to search more then one word?
    • 2034
    Cases are the same except the numbers
    • jruff
      • May 2023
      • 96
      Thank You, I couldn't find any info in Palmers book also
        • 2024
        Year by year G and WL cases are identical except for the VIN number but because G's were made 20 years longer than WL's there are differences in late G cases after the ceasing of WL production. Most of it is cosmetic.
        Jerry
          • 4787
          As stated, there is zero difference in "G" and "W" series cases. There are a minor few differences over the years as to ancillary parts that are added to the bare cases. And things such as waste, not waist can determine search differences . Sometimes it is only spelling and semantics that stop a search.
          • joe fxs fxr
            • Dec 2020
            • 697
            does using " " work for two-word exact searches here?
            AMCA #41287
            1971 Sprint SS350 project
            1972 FX Boattail Night Train
            1972 Sportster project
            1973 HD Golf Cart project
            1989 Springer Softail project
            2020 Heritage Classic 114
            • Scooter6
              • May 2025
              • 31
              Good morning,
              I do not know what year this change started, but the later cam gears and cam cover will not interchange (will bolt up but is different internally). I do not recall if it is just the bushings in the cam cover.
              I do not know, but you may be able to interchange those later gears and the later matching cam cover to an earlier engine. If I recall correct, the later cams are marked with "G"
              I learned this the hard way believing all the parts are alike. One of the later cams for sure has a wider measurement. Those later cams are also marked different.
              Good luck,
              Scooter
                • 4787
                Originally posted by Scooter6 View Post
                Good morning,
                Good luck,
                Scooter
                That is a '59 change when H-D decided to use the same width of the cams for both Sportster and G. It only affects the rear intake cam and cover bushing. But the crankcase itself is the same as WL.
