Looking for a set of Horn brackets as pictured to mount a Horizontal horn on a 37-38 RL springer front end. Found them on Replicant parts site but no longer available and I can find no other supplier. My understanding is that the RL brackets were specific to 37-39 and while similar they're longer and have different angles than the VL brackets. Any help is appreciated!
RL Horn Brackets
These fitted the 1936 RL and the 1937-39 WL while they still had the I-beam forks on the small twin. I would say they should be chromed like the 1936 VL ones. Maybe the Servicar ones were black, but I've seen these with a hole in one side which I don't understand. Yes, they're hard to find and more info appreciated.
Chrome in '36-'37, painted black '38-'39... '38 has the hole in the side...'39 shaped different
HD 37 w.jpg HD 38 w.jpg HD 39 G.jpgLast edited by duffeycycles; 11-17-2025, 08:16 AM.
Thanks for the feedback.
For clarity I'm working on a 39 WLDD still trying to sort out what is and isn't correct on the bike. My intention is to install the missing ride control (which appears to have been mounted lower and adjacent to the springs vs at the top/above style) and in conjunction I'm sorting out the proper horizontal horn assembly and brackets. As per the attached pics I see the shorter brackets on pics of the 36 VL and found the VL version brackets which are reproduced by Replicant. The longer ones for bottom style ride control seem to be less common and more difficult to find and my assumption at this point is that the WL style were built longer to accommodate movement of bottom mounted ride control? That's only a guess and without examples in hand I'm simply going off online pics and what I can find in my books. For what it's worth the Harley 45 Solo "Spare parts" book lists 4859-36 and 4860-36 as the part numbers for the "right and left horn brackets" to fit 1936-39. In any event, my only option at this point appears to be making something or switching to top mount style RC both of which seem less than ideal. If someone comes across a set or knows of a reproduction option please keep me in mind.
Regards
RonYou do not have permission to view this gallery.
This gallery has 5 photos.
Ron, i'd contact David Sarafan. He's gotten me out of a mess or two. I know he's had a few DD's. Good Luck.
David Sarafan <------
*M.A.D.*
Common that parts changed design but part numbers stayed the same as long as they retrofit back to the original part # year. You may need the '39 only style to clear the ride control. Ride control was an option so there were probably very few sets made for the '39 45". I've had one complete set & brackets & slides for 2 more, all long gone. '39 was the only year the front spring fork was drilled for the ride control..Later NOS front spring forks were also drilled, I have one of those made in '43.Last edited by duffeycycles; 11-17-2025, 04:17 PM.
duffeycycles ... thanks and yes my earlier fork has undrilled bosses for the ride control but should be drillable to accommodate the ride control bar brace bolts. Info I found at the below link suggests the 37-38 had undrilled bosses 39 on were drilled? https://forum.chopcult.com/forum/nbs...er-differences
I didn't read all of that but RL spring fork is a little longer than the later spring forks. The springs were too long or stiff, making the rockers sit wrong. The #2 & later castings, 1935-'38 have the undrilled boss for the ride control. Only the #1 casting '31-'34 didn't have the bossLast edited by duffeycycles; 11-17-2025, 04:42 PM.
'39 ride control2.jpg '39 ride control1.jpg DSC_0117.JPG -----------'39 45" only ride control-----
duffeycycles ... I have everything for the ride control except for the spacers that go beside the mounts inside the friction plates. The question I have is whether the spacers have a round ID or if they need to be square inside? If they're round ID I can make them but thinking vibration bumps etc could potentially cause movement so wondering if they're supposed to be square inside like everything else along the control shaft?
The spacers are mentioned on the top of my scribbles. 3/4"OD x 7/16 ID x 1/2" long, round inside not square.
