Lucky SOB !!
Just kiddin with the SOB part.
Yep...work the fits on what you got then. But ??? If you run into bad troubles ? I do have a set of NOS OEM .060" oversize pistons with rings in their original boxes. They are oem nos HD original. Alas though...I provide no warranty, even though they are HD. Really pricy too !
Good luck with the re fitting of the ring grooves Bro. If you need any additional help, feel free to email me direct. Paps
Seriously, I would say that's an average time if everything goes well. If you have a quick change tool post and a good insert grooving tool you could do this whole job in under an hour. Then again, I've seen some old 3 jaw chucks that you'd never get to run true without a lot of shimming and cussing. It all depends on the equipment you have to work with. I worked in a machine shop for a long time and learned it's best not to comment on how long it takes someone to do a certain task. Getting it done correctly is more important. Notce though, that I said you'd likely get charged for two hours. I also learned how machine shops bill.
