1929 DL generator drive question
That book is too far away from the DL. Harley dropped lots of listings as you get further away. I'll look in the '29 and '30 books.Originally posted by Buster View PostI have looked in the 1930-41 Spare Parts book and found no listing for the nut.
Update, the '29, '30 and '31 books all show the armature shaft nut as 0129 but no specs are given on it. Interestingly every year shows a different bevel gear.
It appears to be a 3/8-24 nut.Last edited by Rubone; 09-20-2025, 03:22 PM.Robbie Knight Amca #2736
Thanks for looking this up, I do not have that earlier book. The generator armature shaft is a different separate part. This shaft runs horizontally from camcase to generator bevel gear. The nut I need size on holds on gear inside camcase. Johnny Sells book identifies this shaft as a 1532-29a Generator Drive Shaft Assembly. It seems to be a 5/16” nut and my thread gauge shows 24 tpi, however a 5/16x24 tpi nut just barely starts on and stops. Didn’t Harley use a different type thread pitch in the earlier years.
