34 VD oil leak
  • 34VDharley
    • Jun 2025
    • 48
    34 VD oil leak
    So my Rosie has been misbehaving this morning after I let her sit for about a month. Drained old oil, switched batteries, topped off with SAE 50 high zinc, primed carb, started bike and went "Oh S***, I didn't pump oil into the crank case!". I only had ran her for 20 seconds or so before so I cut off the ignition and pumped 4 pumps into the crank case. When I stopped at work she had a pretty good leak by the chain sprocket. It eventually stopped and I might have lost maybe 1/4 a quart of oil. Did I overfill the crankcase? She seemed to run fine and smooth, but the leak was noticeable. Any thoughts?
  • 34VDharley
    • Jun 2025
    • 48
    Also, anyone know the size/type bolts that secure the tank to the frame? I appear to have lost 2 from vibrations.
    • Peter Cooke
      • Aug 2012
      • 570
      They are #12 x 32 TPI. Replicant Metals sell them.
      3532-18 Tank top mount screws and washers (1918-36 all) nickle
        20 seconds with no oil shouldn't do any harm on a VL. You probably overfilled the crankcase. The hand pump in good condition does about 50 ml/2 ounces per full stroke, and you can check by draining the cases, putting in say four strokes, then draining the cases again into a measuring cup and calculating how much per stroke. Three handpumps should put about 150 ml/6 ounces in the cases, and the idea is to come back after a ride with the same amount.
        • 34VDharley
          • Jun 2025
          • 48
          I can confirm after that scenario I had no further issues with the VD. She ran really well.
          • 34VDharley
            • Jun 2025
            • 48
            Ordered the bolts from Replicant Metals. Thanks!
            • 34VDharley
              • Jun 2025
              • 48
              Well, the bolts from Replicant Metals didn't fit. They're too small? Sucks because they're nice quality but pretty pricey for not working. I'll see if I can get them returned. If not they're up for grabs for anyone who wants them.
              • Peter Cooke
                • Aug 2012
                • 570
                Someone must've drilled & tapped your holes out bigger. Use one of your existing screws to work out what you need and go from there.
                • dukekleman
                  • Jul 2022
                  • 596
                  I agree with Peter.
                  Your other option is to restore the thread back to it's original dimension.
                  Duke
