Repair vin pad 1949 WR and repair magneto mount 48 WR
  • Repair vin pad 1949 WR and repair magneto mount 48 WR
    Is there a correct way to repair the vin pad and what are the correct style and size for the letters and numbers. The cases are A-11. Daytona motor all original, dates all match and still has the Dow Metal pistons. I would really like to get the vin pad repaired before I put the bike back together
    ​ Also at some point I guess someone wanted to run a generator on the 48 WR engine and hacked up the magneto pad. Any Ideas? I'm thinking form it up and pour aluminum from 1945 engine case (old and beat up} that I have. I don't know what the proper way to repair is is, if there is one. this bike runs a side mount Wico
    From my understanding V Twin does excellent pad repair and will even stamp numbers if you have proper documentation. I believe they only will deal with an authorized V Twin dealer. I’ve never had them do anything for me so it’s unverified information. I would think if they do pad repair they would do any case repair. Worth looking into.
      Keep in mind the race motor numbers are significantly different font than standard production. And since race bikes were not required to be titled they often had changed/missing/unstamped blank cases, etc. Many sponsored racers had multiple engine with the same number, so your number may or may not have ever been assigned to those cases.
