Harley Vl brake cable
  • montij
    • Jul 2022
    • 138
    Hi there,
    im changing my 1931 Brake cable and am wondering if anyone knows the original purpose of this old clip on the original brake line.
    Justin Monti
    AMCA #43973
    • 2024
    That is an oiling point for the inner cable and it is newer than 1931. Jerry
    • montij
      • Jul 2022
      • 138
      Interesting. Thank you for the reply.
      Justin Monti
      AMCA #43973
        Yes it has a 1939 part number (before being back dated to 1930). You need the earlier lubricator with a 1932 part number sold by Colony, but this needs the brake cable cutting. The cable lubricator was introduced later 1930 to 1931 with a slightly different style if you want to be really accurale, but this part is not being reproduced as far as I know. There is discussion elsewhere on this site with a picture of the original 1931 part.
        • montij
          • Jul 2022
          • 138
          Thank you for the information Steve.
          I have a question for you. Do you know of anyone reproducing the oil control cable? In the process of routing mine properly behind the rear exhaust I have discovered it has been shortened in the past and will not reach the split throttle block.
          Justin Monti
          AMCA #43973
          • Peter Cooke
            • Aug 2012
            • 570
            Replicant Metals sell the oil control cable.
            3334-12S Control Coil Splitter to Oil Pump
            Here's the 30/31 cable lubricator.
              Dear Montij, I just cut down the early nickel plated throttle cable to make the oiler control cable. Thanks for info Peter and well done Replicant.
