Odd 45 motor
  • mark59
    Mark
    • Dec 2010
    • 32
    Odd 45 motor
    I bought a 67 G trike, that sat around for years i have had it running . Head gaskets leaked Decided to pull the top end and check it out. It has k model pistons and the heads are not modified for popup. The rods have a strange part number ua 706 t 9. So i assume rods to be shorter. Anyone have any thoughts to what I'm dealing with?
  • pgreer
    • Jan 2022
    • 2
    The markings on the rods are standard 45 flatheat rods. So you might post a picture of the pistons and other parts that have been disassembled to see if anyone can spot something that stands out.
    Paul
      • 4789
      Why do you think the pistons are K type?
      • mark59
        Mark
        • Dec 2010
        • 32
        Pistons have -52 part number, I compared w to k piston , k is taller, I stopped by ,a local shop that does vintage engines , they were building a 45 with k pistons the heads cut for popup,
          • 4789
          Late 45 pistons also have a -52 casting number (thin rings) so that in itself does not indicate K. Only the wristpin to top dimension matters.
