1929 Harley DL Motor Modification Question
  • Buster
    • 385
    I have the bottom end of a 1929 DL motor and would like to assemble using the later and longer 1941-1973 45" cylinders and rods. I would be using all 1941-73 parts above the cases and realize I will have to fabricate the valve stem covers. Would the later 1937-73 upper end parts be a bolt on. Thanks!
  • HDSmitty
    • Jul 2017
    • 282
    I don't know for sure but, it seems to me that since the cases you have are from a total loss oiling system, that there may be some issues using a recirculating oil system top end and other parts. I would want to know for sure that everything is going to be oiled as it should before I started mixing parts. JHMO but hope it helps. Good Luck, Smitty
    • Buster
      • 385
      That is a good question. I do know you can bolt a complete UL top end on a total loss VL lower end.
        • 4789
        There is no oil feed to 45 top ends, old or new.
        • Buster
          • 385
          I believe it will work. Going to try it. Nothing else on bike will be correct.
