Vtronic ignition module
  • mark59
    Mark
    • Dec 2010
    • 32
    I have installed a vtronic ignition in my 48 U model stroker.. this unit has 8 advance curves to choose from and one no curve. A unique feature is a separate kick start setting to start motor then after start up it switches to whatever advance curve is selected. The kick start mode is adjustable from 5 to 20 degrees retard. My question is what would be a starting point for degrees of retard?
  • dukekleman
    • Jul 2022
    • 594
    Mark,
    I have no experience with that particular module.
    However, calibration tables I write don't typically go beyond 5 degrees. With your stroked flat head, 5 degrees would be a place to start I guess.
    Tuning is giving the motor what it asks for and wants. Trial and error until you find the proper calibration for a particular combination.
    Duke
      • 2021
      I agree with Duke,stock Shovelhead nosecone is 5 deg BTDC in retard/starting position..Sporty is about 10BTDC
