32E generator conversion
  • montij
    • Jul 2022
    • 138
    C42FBE84-BC97-4A5A-B291-CB1B3510C9F4.jpeg I am trying to rewire my generator on my VL from 3 brush to 2 brush with the generator on the bike. I can’t seem to remove the end cap to access the wiring properly . There is a nut there to remove but it turns the motor when trying to remove. Any help would be greatly appreciated.
    Justin Monti
    AMCA #43973
    • 4789
    That nut doesn't need to come off, the end cap is a light press fit on the bearing. Warm it up with a heat gun or hair dryer and it should slip of leaving the bearing and shims on the armature.
    • montij
      • Jul 2022
      • 138
      Thank you so much incredibly helpful.
      Justin Monti
      AMCA #43973
      • montij
        • Jul 2022
        • 138
        Still a cap in my way. I guess I won’t be able to get any better access to the wiring without removal of the generator ?
        Justin Monti
        AMCA #43973
        • montij
          • Jul 2022
          • 138
          I was able to complete the 2 brush conversion without removing the generator from the bike.
          Justin Monti
          AMCA #43973
            • 4789
            Sorry, forgot the dust shield is under the bearing.
