Delco Remy Horn Assembly
  • Delco Remy Horn Assembly
    In the assembly of my 35 horn assembly, where does the gasket go?
    The assembly, from rear to front: 1) diagram assembly, 2) diagram disc, 3) collar and then the horn cover.
    Thanks, Lippy
    I believe it goes between 1 & 2. Here's a pic of mine from my 31V when I pulled it apart. I have no reason to believe that's not the OEM gasket you can see.
      Thanks, I thought as much but was unsure. Lippy
