Delco Remy Horn Assembly
  • Lippy
    • Apr 2008
    • 114
    In the assembly of my 35 horn assembly, where does the gasket go?
    The assembly, from rear to front: 1) diagram assembly, 2) diagram disc, 3) collar and then the horn cover.
    Thanks, Lippy
  • Peter Cooke
    • Aug 2012
    • 570
    I believe it goes between 1 & 2. Here's a pic of mine from my 31V when I pulled it apart. I have no reason to believe that's not the OEM gasket you can see.
    • Lippy
      • Apr 2008
      • 114
      Thanks, I thought as much but was unsure. Lippy
