Wld, wldr, wr
  • Carter32
    • Jan 2013
    • 19
    Wld, wldr, wr
    We have a pair of 45 cylinders on the work bench with casting numbers 120-39 and 120-391. In researching the number the indication is that these 1939 - 1952 WLD, WLDR, WR. I'm not an expert on 45's can some provide insights as to how to determine which model these might be from?
    This gallery has 5 photos.
    • 2042
    WR has angled valves.,late '39-'42 WLD manifold nut is 2" ...WLDR is 2-1/8" hex nut
      • 4789
      Here is a pair of NOS WLD cylinders, note the valve position relative to bore. '41WLDR "Special" also used angled valve WR cylinders, it did not exist after '41, only the WR continued. Also pictured is a stock 45 cylinder (right), the WLD cylinder (center)
      , and a WR cylinder (left) WLD uses standard 45 valves, WR and some WLDR use oversize intakes. Note factory relief from valves to bore. DCP_3419.JPG DCP_3421.JPG DCP_3420.JPG DCP_4305.JPG
      • Carter32
        • Jan 2013
        • 19
        Duffy / Rubone - Thank you for the information. These cylinders would use two different valve? I'm not picking up on an angle.
          • 4789
          Note how close the edge of the intake is to the cylinder bore. Put a long dowel through the guide hole and you will see that cylinder bore and guide bore are not parallel to each other. Every part used with those cylinders is also angled, the cam face, the tappet shoe (they are flat and not roller type) the tappet guides, etc. Each is numbered and unique to its own position.
