Re torqueing head bolts
  • ldfly112
    • Sep 2017
    • 146
    I am replacing a blown head gasket on a 1937 UL aluminum heads.I very evenly torqued the head bolts in a cross pattern to 63 ft. lbs. just wondering how often i should re torque the bolts THANKS if you can help
    • 8243
    Where did you get that torque spec, Idfly?
    I was taught fifty-five for flatties: Lower compression and more headbolts
    • dukekleman
      • Jul 2022
      • 596
      When it comes to gasketing re-torque on engines, I've done the following:
      1) Initial Torque sequence performed according to engine manufacturer and/or gasket manufacturer.
      2) Re-torque all the gasketing after all heat cycles and piston ring seating sessions are performed. This will fall within the first 10 miles.
      3) Re-torque all the gasketing after 100-150 miles.
      4) Re-torque all the gasketing after 500 miles. Typically you'll find all gasketing has fully compressed and nested by now. I'll usually check gasketing at 1,000 mile service and take note on torque retention.
      Duke
