Help with 30 VL Exhaust Casting
  • eddiepanhead
    • Jan 2007
    • 171
    I have an exhaust casting for my 1930 that is in need of repair. Im lucky to have a talented machinist friend who has agree to attempt to repair the casting I have.
    I have a couple of questions that I need help with:
    What is the length of an unmolested casting? (front to rear)
    Is there supposed to be a lug on the front (back side) of the casting to tighten the casting down on the pipe? like the rear of the casting? (still in place )
    Any guess on the type of cast iron used to make these? Understand that most types of cast iron can't be welded at all
    Does anyone have a usable replacement for this that I could purchase from you? How about the clamp that attaches to it?
  • Tommo
    • Sep 2001
    • 1320
    Here's a nos one with a tape on it. If you need any measurements just ask and before anybody asks it's not for sale DSCF4554.JPGDSCF4559.JPG
    Peter Thomson, a.k.a. Tommo
    A.M.C.A. # 2777
    • eddiepanhead
      • Jan 2007
      • 171
      Thanks Tommo! Would you confirm the length at 4 7/8" overall? Hard to see exactly on photo.
      Would you mind taking a measurement of the inside diameters where the pipes enter? Great piece !!!
      I won't ask
      • Tommo
        • Sep 2001
        • 1320
        5 1/16" front to back and all pipe holes are 1 3/4"
        A.M.C.A. # 2777
          Dear Eddie, I have the top clamp part and the special slotted bolts. The other bolts are 069, sometimes found nos as they were used on the leg shields.
          • chayes
            • Feb 2025
            • 1
            Are these made of cast steel?
            • eddiepanhead
              • Jan 2007
              • 171
              Yes, I believe so. I gave up on this attempt, found two other nice pieces. Still have the one pictured
