Hey Everyone,
Firstly, thank you to everyone who responded to previous questions about my first rebuild. Not really a rebuild, more of a dismantle and inspect, to discover issues that could exacerbate during my second Motorcycle Cannonball attempt. The first one ended in disaster before I even left home on day-minus 3.
My question pertains to the spring ring 3973-30. I believe it is intended to fit into the groove on the axle shaft. If this is the case the one I was sent is too big. If it's not the case, where does recess into in order to hold the bearings in place in the rear brake hub? You can see in the photo the inner diameter of the spring ring sent is much to large to fit the axle hub.
If this is in fact the wrong part, does anybody have dimensions of the actual ring? Is is possible to just replace it with an aftermarket ring from the hardware store? Not my first choice but I also cannot find 3973-30 anywhere.
Thanks,
Lochlain
Thanks,
Lochlain
