James Copper Gaskets
  • JSB55
    • May 2009
    • 332
    Finally got my 1954 45" back from a total rebuild of the bottom end and cylinders. I have iron heads, and have a set of the James copper gaskets with the embossed bead (raised on one side all around, plus encircling the bolt holes). I know to aneal them and use Copper Spray-A-Gasket. What I don't know is which side faces up towards the head, and they aren't marked. Google is no help, but you guys always are.
    Ride it like you can fix it!
    • 8243
    I understand why you would want to anneal a used copper gasket, John..
    Apparently, duty work-hardens them. But shouldn't a brand new one be soft?
    And its been decades, but I thought the OEM gaskets were all the same, so you just flipped one for the other head. Did JAMES make two different head gaskets?
    PS: Please inspect your cylinder decks and heads for "flat" before assembly.
    • JSB55
      • May 2009
      • 332
      Never used them before, and I hadn't broken the seal on the package. They have a little flex to them, but not having used them before, I don't know if that's "soft". From what I'd read, I thought it was standard practice to aneal them all.
        • 4789
        It makes no difference which side is up. And you will find that they are opposite each other since they are the same stamping. OEM are just one stamping.
        • JSB55
          • May 2009
          • 332
          Yup, Robbie, now that I opened the package I see one goes on embossed ridge up, the other down.
          And yes, Cotten, all 4 surfaces checked with a straight edge and a light behind in a darkened room, plus a few swipes with a whetstone reveals no high spots.
            • 8243
            Were OEM copper gaskets "embossed", or "corregated", etc., Folks?
            Does anybody have examples?
            Thicknesses would be great, too, Thanks in advance!
