WLA Seat Scuff rivets/studs
  • ryan
    • Mar 2017
    • 610
    What is the dome diameter of the 6 scuff rivets/studs on the top of the seat? What is the type of rivets: are they jiffy rivets, splashed rivets, bifurcated? Where can they be purchased? I can't even find a good picture of the back of an original seat that shows the type of rivet.
    Thank you in advance for your time!
    Ryan
    Ps: What color is the leather, light brown, dark brown, tan etc?
    Thank you!
    • 8233
    The heads caliper to an odd .475", Ryan,
    So I'm guessing 12mm, and the underside is a normal star rivet 'upset'; I guess that's "splashed"?
    Set with a tool like this...
    Mine is 'patinated' with years of hanging on a wall.
    PS: Upon further inspection, the extreme corrosion upon the rivet heads inspite of no moisture damage to the leather makes me guess they were Park'd. (I don't have Palmer's Military tome.)
    • ryan
      • Mar 2017
      • 610
      Thanks a bunch Cotten!!! That is everything I asked for, now I just need to find a them. Yes, they are splashed, semi-tubular, round-head rivets.
      Will you please show a picture of the, whole, bottom of the seat?
      Somehow I ended up with several aftermarket seats that had military style stamped pans
      so I am making one look more original for my friends wla. I had 5 hours in the pan today which included lathe work, welding, drilling, grinding, rounding front mount rivets with a concave punch and hammer and a lot of hammer and dolly work.
      Ps: What is the, center to center, distance between the .475" rivets, perhaps.750"? Also, are the rivet heads, on the rivets that fasten the leather strip to the pan, .3125" or .375"? Thanks again for your help Cotten!
        • 8233
        The 'scuff' rivets are not evenly spaced, Ryan!
        Nor are they linear; The centers average ~1.060" apart, except for one pair at 1.140".
        The binding strip rivet heads are ~.400", or 11mm, with the exception of the very nose that is an inverted star rivet, and one odd smaller rivet above it.
        .....Cotten
        PS: Bottom surfaces were aggressively cleaned to prevent further deterioration, and by no means original, only authentic.
        • ryan
          • Mar 2017
          • 610
          Thanks again Cotten, I greatly appreciate it!!!! They sure riveted several pieces of leather strap to the pan. It looks like I got all the vent holes in the correct locations, I may run my pan through the bead roller before I am finished.
          I did find the part number for the scuff rivets, but that does not help any. Lol
          Thanks again Cotten for your time and the pictures, you helped me more than you know!!!!
          • ryan
            • Mar 2017
            • 610
            Cotton, I forgot to ask the height of the .475" rivet head, will you please try to measure this please? The .475" rivets look like typical oval head rivets to me, but it is better to check. I think I found a source for the rivets. Again, thanks for your help! Let me know if you need anything sewn, I can sew up to an inch of leather on one of my machines.
            • eddiepanhead
              • Jan 2007
              • 171
              Ryan, Could you share your source for rivets?
              • ryan
                • Mar 2017
                • 610
                I sure will. The finish is zinc plated, so I will park'd them myself. I do not like using steel rivets in seats, but this will be an exception.
                https://catalog.chicagorivet.com/ite...rivets/pn-1073
                  • 8233
                  Originally posted by ryan View Post
                  Cotton, I forgot to ask the height of the .475" rivet head, will you please try to measure this please? ....
                  My best guesstimate, Ryan,...
                  Would be ~.165" (or a little over four millimeters).
                  And I was only guessing they were Parkerized; Maybe they were 'flash' nickel:
                  Palmer's military book should have the correct finish, no doubt.
                  • ryan
                    • Mar 2017
                    • 610
                    Well the .475" rivet head, I found on the website above, are only half that height of the scuff rivets you measured. I think the scuff rivets are called mushroom head rivets, not sure though. However, the company does carry the correct rivets for the straps that are riveted to the pan.
                    Thanks again for everything Cotten! The hunt goes on.
                    • ryan
                      • Mar 2017
                      • 610
                      Well I think I have the scuff rivets figured out. I think they used caps from a lignes 20 snap or a12.5 mm snap cap, which meets the diameter, height and fastening type.
                      Even though there are standard lignes sizes, the unit used for button sizes, this does not mean all lignes(line) 20 snaps have the same cap diameter and cap thickness.
                      Snap size chart
                      https://www.sizes.com/tools/snap_fasteners.htm
                      Location size proof
                      12.5 mm (20 Ligne) Brass Ring Snap Set – 4-part light duty brass fastener for garments, bags & uniforms. 100 pcs bag. Supplied by GrommetMart.
