transmission date code
  • hdhikaru
    • Feb 2010
    • 217
    Hi there,
    this is off from 39 ULH. can you tell if its year correct or not... please tell me how to read this #s. tks Shin
    • 2030
    GO=July 1940
      • 4784
      Originally posted by hdhikaru View Post
      Hi there,
      Does it have the correct shift pattern for '39 with neutral between 2nd and 3rd? Many '39 models had the gearbox changed because people did not like that pattern. H-D changed it back in 1940 to the 36-38 pattern.
      • hdhikaru
        • Feb 2010
        • 217
        thanks guys ... duffeycycles, it might be 50? Rubone, actually it has reverse gear the pattern is R-1-2-N-3-4 looks like year correct?
        • hdhikaru
          • Feb 2010
          • 217
          WOOPS!!
          made a mistake/// shift pattern is R-1-N-2-3
            • 2030
            Shin,Shift lever up is pre '47,the case had clearance for shift lever down in 1950
            • Speeding Big Twin
              • Mar 2010
              • 433
              Shin, date code G 0 indicates the case was cast in July 1940. If it had been cast in 1950 the code would probably have had no letters, only numbers. For example a BT trans case cast in Jan 1950 had date code 1 0. For more info about these date codes and other BT trans case ID here’s a link to a thread I started on the Panhead and Flathead forum in 2016.
              https://www.hydra-glide.net/phpBB3/v...ic.php?t=15569
              Under the trans lid you may find casting number 33-35 and a date code. What’s the date code? Photo?
              Also looks like you have a starter cover but I can’t tell much about it yet. Any ID outside the starter cover?
              Eric
                • 2018
                1940 transmission would have a bronze insert for 5th mounting bolt. 1950 transmission would have a steel insert for 5th mounting bolt. 1950 is also clearanced for down shifting lever.
                Jerry
                Eric
                • Speeding Big Twin
                  • Mar 2010
                  • 433
                  Jerry
                  I mentioned those things in my thread on the Panhead and Flathead forum in 2016 which is part of the reason I posted a link to it. And there I also mentioned other things to look for.
                  Eric
                  • hdhikaru
                    • Feb 2010
                    • 217
                    thank you, guys!! very helpful. Speeding big twin... I do not see any ID anywhere on the kicker cover, so it must be after market. will check the lid later. tks
                    • Speeding Big Twin
                      • Mar 2010
                      • 433
                      You're welcome. No ID on the starter cover doesn’t necessarily mean it’s AM. Maybe it is and maybe it isn’t but I can’t tell much about it yet. It may help if you post photos of its outside and inside. Thanks.
                      Eric
