37 rear brake backing plate
  • ldfly112
    • Sep 2017
    • 146
    the brake backing plate stay has twisted and came out of the frame and brake locked up does anyone have any experience with this and what i can do to stop this from happening again thanks if you can help
  • larry
    • May 2009
    • 247
    Is it the frame or the backing plate that is damaged?
      • 4791
      It is usually caused by the brake cam going to far in its travel and locking the shoes causing the tab on the backing plate to fail. The main reason is too much shoe travel due to worn shoes, worn drums, excessive wear on the pad where the cam rides. Cures are bonded thicker shoes carefully arced to the drum. A replacement drum if it is beyond service life, welding up the contact pad and lessening the cam travel, or a combination of several of those.
      • Carl Olsen
        • Jan 2002
        • 261
        37 backing plates had a smaller brake anchor support on the backside and less rivets to hold it together, it was a poor design and we usually put a 38-57 brake backing plate on to replace it, as it is a direct bolt on and more rigid. If you are a purist, you are SOL
        • ldfly112
          • Sep 2017
          • 146
          it is the backing plate that failed bent the tab almost completely off. they are new brake shoes and repop hub only a couple hundred miles on the bike since complete rebuild I have welded a much stronger piece of steel where the tab was located hope this will help thanks for your comments
