Ul cams
  • jorrow
    • Feb 2008
    • 347
    Ul cams
    Is it possible to change out the cams without removing the cylinders?
    • 2025
    Yes. Just unscrew the valve spring covers and loosen the tappet adjustment, remove the cam cover and hold the tappets off of the cams and out they will come. Jerry
      • 4791
      The only other issue is not being able to shim them except by measuring OAL and comparing them.
      • jorrow
        • Feb 2008
        • 347
        Thanks guys, that helps.
          • 8247
          I've still got some Plastigauge in the cabinet, Folks,..
          But I forgot how I used it.
