Newbie to Flatheads
  • henry187oc
    • Feb 2022
    • 22
    Newbie to Flatheads
    Hello,
    Newbie to this world is antique motorcycles and to the AMCA. I got a hold of a 39’ Flathead and going to start working on it. Been riding for years but never on a bike this old so I’m starting to read manuals and try to learn as much as I can about it.
    First things first I’m going to drain the fluids and give it new plugs. What do you guys recommend for
    oil and spark plugs? Might be a stupid question but really not sure if it matters or not when it comes to these old motors so any recommendations are appreciated.
    Cheers!
    This gallery has 1 photos.
    • 4784
    Hello and welcome to the forum. You should have fun with that bike. However looking at it most of it is '41 and later, so you will need to be sure about years of the individual parts if trying to order spares, etc. Basic spark plugs are D16 Champions, basic oil straight 60 weight which is still available from H-D as well as most aftermarket suppliers.
    • henry187oc
      • Feb 2022
      • 22
      Hey Robbie,
      thanks for the info, appreciate the help.
      and I figured the bike was not 100% original I just said 39’ because that’s what it’s titled as. And yes looking forward to having a blast with the bike and enjoying it.
      tank shifting should be fun
      • kitabel
        • Sep 2018
        • 471
        Welcome, very pretty.
        VIN (left case, just below the cylinders)?
        Number stamped on top of the carburetor?
        Teeth on engine sprocket?
        The Linkert Book
        • Taylorfromtucson
          • Jan 2022
          • 75
          Nice bike! Lose the hinge part of the fender!
          • PaulCDF
            • Aug 2019
            • 1421
            Henry!
            Nice Bike Welcome.
            Two suggestions:
            Check out the Virtual Library of the AMCA
            Check out your local AMCA Chapter.
            ENJOY!
            • JoJo357
              • Feb 2016
              • 3285
              Welcome. Cool looking Flatty.
              *M.A.D.*
              • henry187oc
                • Feb 2022
                • 22
                Taylorfromtucson interesting about removing the hinge part of the fender.. make it more bobberish. What would you recommend for a tail light since that willl be gone?
                  • 4784
                  Not so much more bobberish as just getting that awful reproduction fender off of it. The tail section fit is horrible.
                  Lots of light options, Sparta, English, model A, etc...
                  • kitabel
                    • Sep 2018
                    • 471
                    There are attractive side mounts for the light & plate, but check with your DMV. Some States require the light to be visible from both sides.
                    The Linkert Book
                    • henry187oc
                      • Feb 2022
                      • 22
                      Hey Taylor & Robbie,
                      after taking a look at the bike and picturing it without the hinge part of the fender i think i will go ahead and take your guy's advice. i have ordered a sparta tailight off ebay.
                      Thanks again!
                        • 4784
                        Here is a parts pile 45 I built close to 40 years ago. Not anything on it is the same year...
                        • Taylorfromtucson
                          • Jan 2022
                          • 75
                          Yeah, sparto seems like the go to for that style bobbed taillight. Man, some of those aftermarket fenders fit horribly
                          • kitabel
                            • Sep 2018
                            • 471
                            Examine your shift linkage closely, too many sloppy clevises make gear changes a mystery. If you're not sure of the alignment, a Heim joint can't hurt you.
                            There's a Zerk on the clutch cable tube, make sure it's wet.
                            The Linkert Book
                              Here's a 1938 bobber I put together, with a 1945 U engine. Same deal, parts from all over, but a lot of fun and built as a beach racer.
                              This gallery has 2 photos.
