1949 Harley WL Shift Gate
  • rangofox
    • Jul 2021
    • 14
    Hello,
    I am curious if a 1949 WL uses a shift gate because neither of my tanks have mounting holes. The gas tank appears to have mount for shift lever as well. Did this year not have a gate?
    This gallery has 2 photos.
  • Buster
    • 385
    Your left side tank is for a right side shifter and your right side tank is for a left side shifter. You need to change out one of the tanks to match the side you want the shifter to be on.
      • 4789
      Look down into your left tank and see if the indentation is there for the gate. It could be filled with body filler if the tanks were used on a custom application. All WLs and Servi-Cars have shift gates so there are no exceptions unless mismatched parts as Buster pointed out. Since Servi-Cars had right hand shifter options the mismatch is possible.
      • rangofox
        • Jul 2021
        • 14
        thank you, I See the left tank has the mount for the shifter, i bet it was filled in and painted. I will check when I get home today.
          • 4789
          The mount isn't proof in itself, left side tanks used on right hand shift also have the mount since the crossover rod uses it.
          • rangofox
            • Jul 2021
            • 14
            Under the paint, bondo, solder, and metal strip. The mounting was preserved.
            This gallery has 1 photos.
            • Architect
              • Dec 2014
              • 283
              You got lucky, good for you!!!!
                • 4789
                Luckily they had not cut the pivot off. It must have been set up with a jockey shift, or perhaps even a B&H!
