Servi car speedo drive gear
  • zig1
    • Jul 2007
    • 51
    The new speedo drive has chewed up on the diff of my 43 servicar. I'm looking for a cause . The axle gear has 20 teeth and the drive has 8 teeth. Can somebody give me a measurement for the axle gear position, from the (outer) threaded end of the axle to the gear. The speedo reads with a battery drill on the cable end at the diff. Any other suggestions. Thanks
  • knucklehead 61
    • Sep 2016
    • 350
    are you using the servicar specific drive unit? they are different & have a ring cast into the shaft to identify them.
    • zig1
      • Jul 2007
      • 51
      Thanks for your post . Have added a pic of the drive, I am sure it is correct for a servicar. Do you know if the gear only , unnamed.jpg is available or do I have to buy a complete drive ?
        • 2024
        Yes That is the correct drive for Servi-Car. I do have a NOS drive gear to sell but not the housing. Jerry
        • Buster
          • 385
          The built up area of the axle for the gear is 5/8" wide and the center of this area is 16" from the end of the tapered area of the axle shaft.
