I am working on a 1937 UL 80 inch cylinders my carb. is a Linkert M51. my first question is do i need to replace the venturi with the correct size for the 80 inch cylinders or will it run ok with the 1 1/16 M51 venturi . Question 2. my m51 carb is a 3 line carb what is the difference between a 3 line carb and a 4 line carb . thanks if you can help
linkert carb question
The 1 1/6" will run fine of course, Idfly,..
If all other things are in order.
And may even give an advantage over the 1 1/8" if you are pulling a hack, at the expense of top end you may rarely use anyway.
At four bucks a gallon, you may want the economy advantage as well.
PS: The difference between the two bodies is basically their vintage.
Yes, Idfly!Originally posted by ldfly112 View Postthanks cotton do you have floats in stock now
Floats and manifold reconditioning are the only services I can provide these days.
Please feel free to email me direct at liberty@npoint.net
Looking forward to it,
....CottenAMCA #776
The 1937 UL is a 74" engine, even though it has the 13 fin (casting numbers 120-37 & 371) cylinders they are only bored to 3-5/16".
