45" Harley Flathead Scavenger Pump Problem
  • Buster
    • 385
    Putting together 45" Harley flathead motor. I understand when installing scavenger oil pump to case you tighten 4 corner nuts that hold it to case and then tighten two center center bolts that hold pump halves together. After I tighten 4 corner nuts the pump spins freely,. When I then tighten two center bolts the pump tightens up and does not spin freely. Can I install two gaskets between the upper and lower halves of the pump for additional spacing or what is my problem. Thanks!
  • Buster
    • 385
    Just figured out the two gasket solution is not an option on an oil pump.
    • Buster
      • 385
      I found the problem. Took out the new replacement gasket and inserted old gasket. Now pump turns freely. The old gasket is a couple of thou thicker then new gasket.
      • BigLakeBob
        • 2768
        Can you post what the 2 different thicknesses are? Thanks.
        Bob Rice #6738
        • Buster
          • 385
          The new gasket is 0.015" and the old gasket that works is 0.019". Got the new gasket in kit from 45 Restoration so dont know who made it.
          • BigLakeBob
            • 2768
            I am new to 45 motor assembly and getting ready to do a '38 and '48, why to your statement?
            My gaskets from Eastern are about .011, so to my above question if I have the same problem as you. Doesn't gear cavity wear and gear thickness have a say in gasket thickness?
            Bob Rice #6738
            • Buster
              • 385
              There could be wear in mine. I would try the .011 gasket and see if pump turns freely. Mine would bind when I put pump on crankcase and tighten two center bolts. The Military Manual says to not tighten these two center bolts until the four corner nuts have been tightened to case.
              • kitabel
                • Sep 2018
                • 471
                I could swear that the Dixie military surplus gaskets were paper, very thin, never had a problem.
                The Linkert Book
