How does a front fork ride control work? I assume it restricts spring rate / bounce. Does it work well or is it unnecessary. I guess my other question is when is it necessary to have a front fork ride control on your bike? Thank you. 6C408DFE-D5A3-46C1-AC39-AC3601AC0871.png
You need it as soon as you get tired of bouncing down the road.Be sure to visit;
- 1 like
It is simply a friction device used to somewhat control the bouncing movement of the springer front end. In later HD models a hydraulic shock absorber (similar to a cars) was used. I don't have one on my VLD but it is a matter of personal preference. If possible maybe you could try a friends bike that has one to make the comparison. Hope this helps.....Smitty
- 1 like
I'm sure it would affect tire wear also and I had the opportunity to get a really nice one from Dave at Harbor Vintage at the Terryville meet.....just wasn't in the budget at the time. Also somewhat of a real pain in the neck to install on my 36 with 1 yr. only spring shield (cover) on the springer. Yeah....that's my excuse...not the money, just the hassle we'll go with that.
Harley made them as accessories, part 11250-30, and for 1936 they would have been part of the standard accessory package. I would fit the steering damper first to stop side to side shimmying, but I've had pogo-ing over concrete roads at about 40 mph which is pretty unpleasant, and fitting the ride control cured it.
rebound damper
Since it has the same effect regardless of which way the fork is moving, it's just a damper. Some hydraulic shocks are direction sensitive (more damping on compression than rebound, or the reverse), but not friction devices.
How would it affect tire wear?
