VL Footboard Supports
  • downunder vl
    • Oct 2009
    • 143
    VL Footboard Supports.
    Can anyone please advise me the positioning of the VL footboard supports pictured. I have numbered them for identification.
    One also has a longer thread. What was this used for?
    This gallery has 1 photos.
  • Peter Cooke
    • Aug 2012
    • 570
    Hi Phill, the 2 with the same length square section go on the right hand side. Those look like #2 & #3 in your photo. I'm sure I've read somewhere that the one with the longer thread goes to the front possibly to pick up a sidecar brake bracket or similar. So #2 right side front & #3 right side rear. On the left side the shorter of them, #1 goes to the rear leaving #4 for the front.
    Hope that helps.
    • downunder vl
      • Oct 2009
      • 143
      Thanks Pete,
      That's what I thought without knowing the reason for the longer thread. I was pretty sure that the two of the same length went on the brake side but not whether the one with the longer thread went to the front or the back. You explanation sounds feasible.
      I'll give you a call.
      Regards
      Phill
      • Peter Cooke
        • Aug 2012
        • 570
        Originally posted by shermanpup
        I am looking for the same info for a 34 RL if anyone has any to share . Part #'s would help too Thank you
        You should start with Johnny Sells book.
        Vintage Motorcycle Works
