Harley VL short spline brake hub with long spline wheel hub
  • Buster
    • 385
    I am running Harley VL long spline rear wheel and brake hubs on my 1931 VL. The brake drum is poor and I have a good rear brake drum and hub with short splines. I want to use my current long spline wheel hub with the better condition short spline brake hub/drum. Is the only part I need to change the current 3959-32 long spline axle sleeve to the short spline #3959-30 axle sleeve. Thanks.
  • Peter Cooke
    • Aug 2012
    • 573
    Buster, the description & illustration in Steve's book would suggest that you are correct. The only difference between the 2 assemblies is the axle sleeve being for the short or long spline brake hub/drum.
      I stopped making the two VL rear axle sleeves and have no plans for more, so they are getting hard to find in good condition.
      • Peter Cooke
        • Aug 2012
        • 573
        Tom has them available Steve.
        3959-30 rear sleeve (replicantmetals.com)
        • 26fhead
          • 94
          Competition Distributing has them as well.
          Steve
          • Buster
            • 385
            Thanks everyone. I have one on order now.
