VL cams Reconditioning
  • scooterscum61
    • Jan 2021
    • 46
    Is there anybody resurfacing and regrinding cams out there ? or any way to recondition slightly pitted cam lobes . I know you can get new cams for a UL from Andrews but what are your options for a VL. . Any Help appreciated .
    I've sent Andrews a set of used VL cams last year, and told them more VLs were made than ULs, but no response so far. I hope they make them because good VL cams are getting hard to find. If you only have light pitting or scoring I would let it go, as the cam surface is pretty forgiving with those roller lifters. Clean up the lifters in solvent and you may find movement in some or all the rollers, in which case put in a new roller set which is not big money. I have had some street/race cams made with a UK specialist, with more lift and overlap, by welding the lobes and reprofiling. The WL guys are doing the same, trying to turn them into WRs, so that might be a better contact for you. Without seeing the cams, I'd say change the rollers and sit tight.
    • scooterscum61
      • Jan 2021
      • 46
      Thanks , Steve I will keep my fingers crossed and hope Andrews responds . Meanwhile I have the rollers in the works along with other pieces to the puzzle ,enjoying the journey every step of the way, Thanks for your feedback .
      • Eric
        • Nov 2002
        • 148
        http://www.harley-memories.com
        http://harley8valves.wordpress.com/
        AMCA Membership#5701
        • joe fxs fxr
          • Dec 2020
          • 706
          Originally posted by Eric View Post
          Website blocked due to trojan
          AMCA #41287
          1971 Sprint SS350 project
          1972 FX Boattail Night Train
          1972 Sportster project
          1973 HD Golf Cart project
          1989 Springer Softail project
          2020 Heritage Classic 114
          • Eric
            • Nov 2002
            • 148
            Camshafts
            For CARS, MOTORBIKES (manufacturing and repairing original camshafts or camshafts for competition), Jet ski, Boat, Cross car, Go-Kart, Buggy, 4-W Drive, Classic VEHICLES, TRUCKS, TRACTORS , BOATS,Industrial motors, Proto Marathon Shell, Scale models...
            TECHNIPROFIL offers:
            - Rectification of camshafts,
            - Manufacture of steel camshafts (subject to study),
            - Repair works,
            - Coating,
            - Reading of the cam’s lifting pattern on a test bench,
            - Cams’ drawing on a graph plotter,
            - Producing cams from a model, from a list, ...
            - Computerized creation of cams profiles.
            - Works for any type of engine (from mono cylinder to V12) in 2, 3, 4 and 5 valves per cylinder.
            More than 7,600 different profiles of cams have already been created and new creations are achieved every day for Rally, Raid, Racetrack, Dirt track, and Ice track...
            Caution! All of our works are for a specific use. Using modified camshafts is strictly reserved to competition on a racetrack. If used for a competition that would pass by a public road (rally – hill climb...), please conform to the rules and legislation in force of the country.
            Contact us for your specific needs! Email: techniprofil@gmail.com
            Manufacturer: Gérard Augereau
            Date of creation: 1985
            Topics covered: camshafts, rectification, cutting, control, manufacturing, cam study, repairs, car, motorbike, classic, collection, industrial motor.
            Specificities of the activity: works per unit and in small production.
            Specific profiles already achieved: more than 7,600
            Clients: worldwide professionals and private individuals.
            • EricOlson
              • Jan 2011
              • 581
              scooterscum61, I recently opened up my U model and found one cam with damage on it. I did some asking around and found two shops that looked promising for repairing the cam. They were http://www.oregoncamshaft.com/index.html and https://leinewebercams.com/. In the end I decided to replace all the cams with a set of Andrews so I can't personally attest to the quality of their work, but I can say they were both responsive to my emails and questions. Good Luck.
              Eric Olson
              Membership #18488
              • scooterscum61
                • Jan 2021
                • 46
                Thanks Eric I will definitely check it out .
                • kitabel
                  • Sep 2018
                  • 471
                  Much cheaper to find another set of cams. Remember 1930-33 vs. 1934-36 based on which cover and pump.
                  The Linkert Book
                  • Paps
                    • Jun 2003
                    • 1814
                    Pitting is really not an issue but does depend on where the pits are located on the lobes. If the the lobes are within factory specifications, pitting may actually help lubricate the the lobes. Small pits here and there are nothing to be concerned about.
                      • 8247
                      Just how much spring pressure do VLs have, Folks?
                      "Pitting" implies only corrosion; 'Spalling' to where crystal structure shows under magnification is something else...
                      I have found many OHVs running pitful cams with little problem,.. until the rollers gave it up.
                      Needle rollers really need hydraulics; What's a Flatty or Knuck to do?
                      • Eric
                        • Nov 2002
                        • 148
                        See Techniprofil job on my 8valves cam here : https://harley8valves.wordpress.com/...rley-8-valves/
                        • scooterscum61
                          • Jan 2021
                          • 46
                          That looks great, they did nice work . I was able to get a hold of Leinweber's and sent my cams out after talking to them . I had heard about them years ago and again from your link The owner Jim is 86 and his son now runs the shop . I spoke with Norma , Jim's wife Very nice person and extremely knowledgeable we had a valuable conversation . They are going to get back with me once they assess the work to be done . Thanks for the lead I will let you know how it progresses .
                          • EricOlson
                            • Jan 2011
                            • 581
                            Glad it's looking promising!
                            Eric Olson
                            Membership #18488
                            • Scoot48
                              VL enthusiat
                              • Jun 2009
                              • 6
                              Scooterscum, I expect my set of VL cams to arrive tomorrow from Leineweber. As you said very knowledgeable and customer focused. I had mine reground for more lift, but they'll do what ever you need. Justin called after assessing and was very helpful. The cost to regrind with heat treat and shipping was less than a set of good used cams these days. Seeing is believing though, I'll let you know what the delivered cams look like. Good luck with your VL project.
