18" Kelsey-Hayes 45 rear rim
  • Twister the fitter
    • Jun 2019
    • 63
    Anyone have any ideas or experience with regards to repairing some outer rim damage to a KH 18" 45 rear wheel ? I was thinking of adding some brazing or lead to build up damage and blend repair back into rim's finish. The damage is very slight and shouldn't add much to the balance of rim. I really don't want to use any putty, unless that's the norm for this type of repair. Any help and suggestions are appreciated for this ORIGINAL wheel ! Thanks, Twister the Fitter
    • 2025
    If you are going to fix minor imperfections in a rim do not use weld or brazing. Too easy to distort the wheel. I have used lacquer putty which is jellied paint and under powder coating I have used lab metal which can withstand the heat from the powder coating process.
    Jerry
      • Jun 2019
      • 63
      Thanks Jerry, I think I'll give that stuff a try. It only gets repainted with period correct OD paint anyways. Twister
