Harley Davidson WL squeaks
  • epazikas
    • Dec 2018
    • 104
    Hello Forum, my WL was refreshed with new cylinders, pistons, piston rings and valves. Everything worked fine for the first 600 km, then I started to get a squeak noise when kick starting....
    I was told it could be the clutch plates, which in fact were worn and I also refreshed them, but the noise is still there.
    check the video:
    Could any of you give me some hints on what it could be and how to fix?
    thank you and Merry Christmas and a Happy New Year to you!
    Ed
  • pan620
    • Oct 2016
    • 223
    My guess is one of your head gaskets is leaking.
      • 8247
      Pull a sparkplug or two, Ed!
      And see if it still does it.
        • 8247
        You aren't running copper head gaskets with aluminum heads, are you, Ed?
        With the plugs back in, kicking it with soap suds around the gaskets might pin-point problems.
        Snoop particularly over the intake and exhaust ports....
        Let us know!
        PS: I really swear by torsion torquewrenches: 55 ft-lbs cross-cross pattern, of course.
