Early guide fender light with wire connection on the bottom
  • Sidehacker
    • Sep 2012
    • 235
    Hopefully this is an easy one. Does anyone know the thread size and length of the screw that holds the electrical wire on the connection.
    Sidehacker
  • ammorest
    • Sep 2008
    • 301
    According to the 1941-54 parts book it is part number 2586, 6-32 by 1/2 inch round head machine screw.
    • Sidehacker
      • Sep 2012
      • 235
      6-32 -1/2 long is wrong at least with the 6/32. And I believe 1/2 might be a little too long. Maybe 8-32 I'm going to try to run a 8-32 tap through it . I will just use my hand on the bit to see if this is correct.
      • ammorest
        • Sep 2008
        • 301
        Just goes to show you can't believe everything in a Harley parts book. Checked a couple of light bases and they are 8-32. 3/8 long would be plenty.
