Oil pump vane problem
  • Oil pump vane problem
    Took the oil pump apart, the adjusting screw was torqued in and difficult to get out. The photo shows a wear ring around the ball. Then there are the check valve springs that came out. Looks like someone just used whatever they had laying around.
    Burnished the seats put in the new springs etc.
    Problem:
    The vane spring pockets have an ID of .148" but the spring has an OD of .154" so the springs don't fit.
    I can use the old spring with the new vanes (that spring is .100" longer than the new one in the kit) or I can use the new spring with the old vanes which are worn .010" each.
    Guess I could try to drill out the new pockets but that could be difficult and they are hardened I assume.
    I'm thinking of using the old spring...any advise?
    Also:
    How do you adjust the adjusting bypass screw?
    Mike
    Mike,
    I would use the old springs. They are only about .030" shorter than some NOS ones I have.
    Springs too short will not allow pump to build as much pressure.
    Correct adjustment on the bypass screw is 3/8" below the top of the oil pump body.
    Hope this helps.
      Yes, that is a huge help...thank you.
      I went ahead and put the old vane spring back in tonight but had no clue about the bypass adjusting screw.
      Now I'll reset it to 3/8" below tomorrow evening.
      Thanks again.
      Mike
