UL frame identification
  • shyambiker
    • Nov 2019
    • 26
    Originally posted by Speeding Big Twin View Post
    On the left axle clip the die number looks like 5 and apparently 5 was used for about 1941–44. On the steering head the die number looks like 8 which indicates 1942–43.
    Both those die numbers are consistent with what the other two die numbers were suggesting: a 1943 model frame.
    Eric
    Thank you Eric.
    • shyambiker
      • Nov 2019
      • 26
      Originally posted by shyambiker View Post
      Thank you Eric.
      Hi Eric,
      Can you please let me know where does this Speedo clip fit on the ul.
      Part no : 67075-36
      If possible a picture please.
      Regards,
      Shyambiker.
      • Kozy
        • Feb 2004
        • 129
        Hi Eric,
        Part no : 67075-36
        Regards,
        Shyambiker.
        On center case stud just above VIN No.
        • shyambiker
          • Nov 2019
          • 26
          Thank you kozy.
          • shyambiker
            • Nov 2019
            • 26
            Can you also please let me know where does this throttle bracket fit on the cylinder head.07DB2166-E18A-4E91-B2D2-E7A01AFE1B6B.jpg07DB2166-E18A-4E91-B2D2-E7A01AFE1B6B.jpg
              • 4789
              Not on a UL.., rear cylinder stud as stated previously. The carb support is on the center stud on the left side.
              • Kozy
                • Feb 2004
                • 129
                Thanks, in the picture I attached the clip is installed upside down. Used on OHV only?
                  • 5955
                  Look at the picture I posted above. It shows the correct clip and location.
                    • 4789
                    Kozy,
                    The OHV clip is shaped differently than the SV type. The OHV is a one piece heavy spring clip, the SV is two piece with a compound bend to line the cable up correctly.
                    • Sargehere
                      Member since 1972
                      • Jul 2006
                      • 971
                      Can you also please let me know where does this throttle bracket fit on the cylinder head.[ATTACH=CONFIG]26581[/ATTACH][ATTACH=CONFIG]26581[/ATTACH]
                      Front cylinder head, UL, under a head bolt. There is a special provision in form of a detour of one fin out-of-the-way to accommodate that where it belongs on a stock head.
                      Gerry Lyons #607
                      http://www.37ul.com/
                      • Speeding Big Twin
                        • Mar 2010
                        • 433
                        Hi Eric,
                        Part no : 67075-36
                        Regards,
                        Shyambiker.
                        Speedo cable clip #67075-36 was formerly known as #11136-36 and according to one of my H-D catalogs it was not only used for certain OHVs. It was also used for some BTSVs, at least for 1937–38, and it connected to the top case stud just above the serial number. See the photo posted earlier by Kozy.
                        Throttle cable bracket looks like #3371-37 (new #56604-37) and it looks like it’s visible in Kozy’s picture. There’s also a photo on page 129 of volume one of Palmer’s second edition if you’ve still got it? And you’ll get another view of that bracket on page 304.
                        Eric
                        • shyambiker
                          • Nov 2019
                          • 26
                          #27
                          Eric
                          Thank you so much.
                          Regards,
                          Shyambiker.
