UL frame identification
  • shyambiker
    • Nov 2019
    • 26
    Hi friends,
    I am new to the group.
    I am restoring a 1946 UL and would like to confirm the frame on my bike is correct 1946.
    Please let me know.
    Regards,
    Shyambiker.
    [ATTACH=CONFIG]26448[[ATTACH=CONFIG]264426E56F65-E6F5-41C9-A664-4944F55B8684.jpg9[/ATTACH]/ATTACH 68965478-25F7-4E00-A98B-05F8ADFA45AC.jpg4474E1B0-73A1-4675-88F2-5EB6F476F6B0.jpg
    • 5955
    Starting in October 1944 welding was done on frames. '46 frames were welded. Only the neck and rear axle clips were brazed. All other joints were welded. You can find this information on page 812 of the Second Edition of "How To Restore Your Harley-Davidson".
    • 1950Panhead
      • Jun 2010
      • 343
      XE6 die number #3 was used in 43 and 44.
      Post photos of frame neck, both sides.
      • shyambiker
        • Nov 2019
        • 26
        Additional pictures UL frame
        • knucklehead 61
          • Sep 2016
          • 350
          definitely not a 46 frame.
          • Speeding Big Twin
            • Mar 2010
            • 433
            Shyam, welcome to the forum. On the Panhead and Flathead forum you mentioned you got hold of volume one from the second edition of Palmer’s book. Do you still have it? If so please check the chart on page 45. Die number 2 on the rear motor mount, when combined with die number 3 on the R-H axle clip, suggests the frame may be a 1943 model.
            What are the die numbers on the R-H side of the steering head, on the left axle clip, and underneath the seat post forging?
            And are any numbers stamped on top of the seat post forging?
            Also, did you get the engine serial number and belly numbers authenticated yet?
            Eric
            • shyambiker
              • Nov 2019
              • 26
              Thank you so much.
              • shyambiker
                • Nov 2019
                • 26
                Eric
                Hi Eric,
                I am attaching the pictures as suggested.
                Here in India we have only 3 or maybe 4 UL's.
                So there is no system to get my bike authentication done we have to go by what we have in hand.
                Also the restoration is on the end so now this is just academic interest.
                I will also post the pictures of the restoration later.
                Thank you for the help.
                Shyambiker.3368FE57-2E46-4E62-B45A-D489370A2412.jpg431FC0AF-4772-4E45-AB1D-1AACD1D003A7.jpg6CE2061A-1372-42D9-8DD7-362E648FC80A.jpgD6AB71B7-E572-44AA-A763-6B7069978156.jpg3D335A65-C616-45C7-BD2B-6F7134216135.jpg
                • Speeding Big Twin
                  • Mar 2010
                  • 433
                  You're welcome. Thanks for the extra pictures but I can’t read the die number on the R-H side of the steering head or the left axle clip. What are the die numbers?
                  Regarding authentication of the engine serial number, the idea was to be sure about the model year before spending money on restoration. Perhaps you could post a partial photo—for example, 46UL1+++. And you could do a similar thing with the belly numbers—for example, 46-1+++. Then we could give you an opinion on whether the numbers appear factory stamped or not. It’s even possible the belly numbers could begin with 47- and Palmer mentioned it on page 10.
                  Eric
                  • shyambiker
                    • Nov 2019
                    • 26
                    Eric
                    Hi Eric,
                    I am posting the clear pictures for the right side steering head and the left loop and left axel clip.52C18D5D-7406-454C-B197-00D09BE13E30.jpg
                    Will post the engine and belly numbers when I go to the garage.
                    Regards,
                    Shyam biker.5910532D-6205-467B-A6B7-F4AE22BE0C6D.jpg4431F39A-0ABD-4FFB-9F0C-9C141BCA06B3.jpg
                    • shyambiker
                      • Nov 2019
                      • 26
                      Hi Eric,
                      Also please let me know where does this speedometer cable clip fit.
                      If possible supported with a picture.
                      Regards,
                      Shyam.572BFCA6-6E2C-4605-B1B1-166C6D26B0CA.jpg37512E67-F45F-4492-A60E-BDF2626B1936.jpg
                        • 5955
                        • 1950Panhead
                          • Jun 2010
                          • 343
                          Under left rear cylinder nut.
                          • shyambiker
                            • Nov 2019
                            • 26
                            Thank you Eric.
                            • Speeding Big Twin
                              • Mar 2010
                              • 433
                              On the left axle clip the die number looks like 5 and apparently 5 was used for about 1941–44. On the steering head the die number looks like 8 which indicates 1942–43.
                              Both those die numbers are consistent with what the other two die numbers were suggesting: a 1943 model frame.
                              Eric
