Linkert M41 boring-lapping
  • NCriding
    • Jul 2014
    • 71
    Any recommendations on a machinist that can repair Linkert carb body wear from a throttle plate? The wear looks pretty significant, plus there are some weird chatter marks, not sure how those occurred.
    Saw a YouTube video of a west coast guy (Tatro) that solders up the gouges, then bores the solder and laps it back to size. I'm in Atlanta so would prefer to work with someone closer to this side of the country if possible.
    1936 VLD in process
    1969 Honda Z50 K1 perfect!
    1985 Yamaha RZ350 resto-mod
    2006 KTM 950 Adventure
    2019 KTM 300 XCW
    • 8233
    Its routine for me, NCriding!
    I hone away the wear, cut a throttledisc, and swage the venturi oversize.
    Unfortunately, I'm booked solid; But I'll tell you how to do it.
    • NCriding
      • Jul 2014
      • 71
      Cotten!
      Thank you, I would very much like to do this myself if possible. I have a nice Jet lathe and Jet Mill at my disposal, but lack the hones and expandable lappers, and the experience or knowledge to use it. Any advice or instructions would be much appreciated.
      I’ve read your posts that you are no longer accepting new work or customers, so did not want to bother you directly.
      NCriding
      1936 VLD in process
      2019 KTM 300 XCW
        • 8233
        Its only a moratorium on new customers, NCriding!
        (I'm losing the Schebler Wars.)
        Much of your tooling can be made on the lathe and mill, but you are really going to want a hone.
        Unfortunately, it invariably burrs the idle bleed holes if you set up and lathe-cut the bore, but you may have to...
        • NCriding
          • Jul 2014
          • 71
          Success at last! Successfully soldered the wear grooves, reamed it (very carefully), honed it, then tried my hand at Nickel plating. I used Caswell plating crystals and electrode, and think it turned out pretty well.
          1936 VLD in process
          2019 KTM 300 XCW
