1945 wld
  • oldsport
    • Jul 2014
    • 38
    1945 wld
    I would like to converse with some one that owns a 1940 WLD 45 with the (narrow clutch, two bolt transmission assembly) OEM style primary cover assembly installed. I am having a problem, the shifter rod interferes with the inner upper primary panel at the transmission lever end. The back side of the hook end rubs hard against the panel making it difficult to "feel" a shift change.
    Also, does any one know the purpose for the small access hole (trap door?) (mouse hole?) in that same inner upper primary panel?
  • RCamp
    • Jul 2012
    • 99
    You need an OEM or OEM style shifter lever that uses a clevis pin
    • oldsport
      • Jul 2014
      • 38
      Is there a part # and perhaps a source for the clevis pin type shift rod?
      • len dowe
        • Oct 2002
        • 520
        https://www.ebay.com/itm/Harley-1941...EAAOSwFLBaTusG
        Shop around. I remember seeing them for 25.00 not long ago.
        AMCA #765
        • len dowe
          • Oct 2002
          • 520
          https://feedback.ebay.com/ws/eBayISA...ab=AllFeedback
          Penny has them for a good price. Just ask her.
          AMCA #765
          • oldsport
            • Jul 2014
            • 38
            And whom might Penny be?
            • len dowe
              • Oct 2002
              • 520
              The ebay seller on the 2nd link I posted.
              The first link is Colin. He's a great guy to deal with as well.
              AMCA #765
